Help Needed, Disc's And Break Pads !
happydaze
Recently had a 60k service done on my IS200 sport which cost me £460.00.
The only things needing seen to where the front discs and the front and back break pads need replaced.
The problem being, i can't live with the price they have quoted me.
I'm planning on sourcing the parts myself and getting it done at a local garage.
Any suggestions for Discs i should get and break pads. Had a look on e-bay and i can get front and back Discs.
Don't want to make the wrong purchase. Any advice would be much appreciated.
Thanks. :winky:
Alot of people recommend Mintex discs and pads like these Front and Back. But if you're going for looks as well like i did then get the RS-10 grooved and dimpled discs from 3G, but they are more expensive. 3G discs or get it from their website HERE. I'll be replacing my rear discs soon with 3G discs and mintex pads.
They look like this.
Try not to go with drilled type discs unless it's a well known and pricy brand as you will find they will warp and as monster mat says "Buy cheap, buy twice".
It's worth spending a few more bucks on brakes and tyres as you have that peace of mind.
i had mintex front discs and pads fitted about 2 years ago and their still going strong, not had a problem with them.
two weeks ago had mintex rear pads fitted. so thumbs up when it comes to mintex from me.
bought the mintex discs and pads off ebay and like u sed had a local garage fit them.
it's not a big job.
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
