hi, could i have opinions please on why my drivers side front tyre is worn on the inside. the 3 inches or so innermost are bald and the rest is ok. would it be a wishbone or something.
all other tyres are ok.
i assume im looking at an repair bill.
Could be tracking out. lower ball joint or upper wishbone ( normally wear on outer edge though) I would get the tracking looked at first ( unless you have any obvious creaks or knocks from the suspension)
Do you regularly have to straddle one of those wide speed bumps ?
Oh yes, get the tracking examoned and reset.
Mine was doing similait and wearing the out side edges.
I used Wheels in Motion
http://www.wheels-inmotion.co.uk/steeringgeometry.php
they have the hawkeye system and I had the front and rear measured, and adjusted, for £95.
Some of the settings were well out.
I have the geometry spec for 1955 MK-III cars if you need it.
Remember that everytime you hit a big bump, pot hole or kerk, it could get out of alignement.
Can we have a whip-round and get you a proof reader ?
Why?.... I understood it perfectly.
why for two spelling mistakes?
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
