Changing Alloys Are These Measurements Ok?
yes they fit. you will need center rings from 75mm to 60,1 mm and 5mm spacers for the rear is good but not a must
try 225/40/18 for rubber. running this as winter tires here in sweden and 20" summer without problems
Hi mate, so i will need spriggot rings at 75mm for all four wheels??
and then 1mm spacers for the front and 5 mm spacers for the rear?
is that right lol?
correct me if im wrong mm8
yes 75mm to 60,1 for the rims and front spacers not needed but rear if you want.... they sit a little to far in in my opinion.
here you can see my 20" and they are et 38 plus 5mm on the rear nothing on the front. just think the rear look better with 5 mm
http://www.lexusownersclub.co.uk/forum/ind...59373&st=20
