Amp Location - Is300
head units started playing up (just waitin for the final 'error 3' code!) so replacing with a double din touch screen jobby (not decided on a make yet, theres loads out there!)
going to replace each speaker and run fresh wiring to run from the head units power (most head units are upwards on 50w per channel now, which is enough for me) and then add a small amp/sub combo and bit of a built build thru the ski hatch.
well aware of the fascia adapter process and can easily whip up some adapters for the fronts.
anyone know the whereabouts of the factory fit amplifier i an IS 300?
