Is200 With Merc Wheels
ormi
there tsw legend 20" which i'm going to paint astral black the same as the car
and the best thing about them is there is 5 different bolt patterns on them so easy to sell
Are they 20"? Interested to see more pics too, always thought 20s were too big for the IS but in that pic they look ok :)
you dont need converters... wobble nuts or something i think does the job... yeah both cars are from over here in northern ireland aswell...
Bang on mate. As the IS200 has a high offset there's no way those merc wheels would fit if PCD adaptors were used, as the minimum thickness of the adaptors would be 20mm, making the final offset way too low on wide merc wheels, which will be between ET37-ET27 to begin with.
That means these have been fitted with 'wobble bolts' or PCD variation bolts to give them their correct name. Most wheel specialists do them, and they're pretty safe to use, although I wouldn't personally use a set.
  • 2 months later...
