Alternative Cd Unit For A 03 Is200 ..help
error 3 is a common problem with the lexus head unit so i would advise to go for a after market head unit or if you could find a cheap lexus head unit but then again it may have the same problem after a while.
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
