Debadging?
Haven't done this so am no expert, but yes heat up with a hairdryer - don't prise off, but gently move the floss from side to side to sort of cut through the adhesive. Washing up liquid should work on the excess glue, or people often talk of this stuff called goo gone but haven't tried it myself.
Debadging
So last year ( IMHO ).
Try WD40 on the glue but don't rub it too hard.
I would use Autoglym Tar Remover (from Halfords £5.99 )-this is excellent for removing glue,tar.bird droppings and any other marks from your car. It is also totally safe and wont damage your paintwork.
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
