Interior Dash Lighting...
Hi, have any of you guys changed your dash bulbs?? As mine are quite dim I think i might change them, I found this guide (http://my.is/forums/f90/how-change-your-main-gauge-cluster-ignition-ring-lights-leds-pics-359216/) (although it is American it should still work on ours shouldnt it?)
any of you's done similar?
Kev
did you go ahead with this mate?
i would be interested in changing mine too.. if its easy enough :-)
Izzy
Kev
Yes it's the same car :)
Only difference is the steering wheel is not on the wrong side and the engine is 1 liter bigger
