Ccfl Lexus Is200 Halo Headlight Rings
hunty
You have to open up the headlights by heating them with a hairdryer then start taking them apart which will take about 30 min or something for each headlight. When the headlights are open you are likely to find out that the angels eyes won't fit so you have give up fitting angel eyes and reseal the headlights without them and after resealing you are likely to get water in your headlights.
Don't bother :)
done mine no problem followed the guide on the forum,, they were a almost perfect fit used a very high tac super glue to tack them in place,, detangoed mine wilst at it, mine were already having issues with steamin up before i even thought of halo rings, before i resealed them i stuck two packs of silica gel inside them just to make sure any remainig moisture had gone,and ive never had issues since-- however unless you are very confident at d.i.y i would not recomend
  • 1 year later...
What did you reseal yours with? how did you open them?
