Temperature Gauge
SteveLS400
Hi
For those that follow the LS400 sub forum, this will be familiar.
The engine temp gauge packed in for no apparent reason. The gauge works when shorted. Its had 4 new sensors. Ive even removed the plug fron the wire and soldered the wire directly to the sender. It worked in a fashion for a month or so, and now nothing again.
In a desperate plea for help, can anyone throw any light on this problem. Car has never overheated but I cringe in jams. The full details are here:-
http://www.lexusownersclub.co.uk/forum/index.php?showtopic=61124
is it not worth trying to find one in a scrapyard and ripping out as much of the system as possible ie senders and loom,maybe dash to replace yours with - or even try a sender off another car with similar fittings to try to give you some sort of temp display
Hi
Mine's a'94 so this may not apply but the manual show another test.
1 Disconnect the connector from the GAUGE
2 turn on ignition gauge should read cool.
3 ground SAME CONNECTOR through a 3.4watt bulb
4 switch ignition on, check bulb lights and needle moves toward hot.
If not right measure the resistance on the 3 terminals on the gauge,B at 12 o'clock,A at 7 oclock
C at 4'oclock
connect A-B approx 54 ohms
A-C approx 146 ohms
B-c approx 200 ohms
If values not right change the gauge
Worth a look, have no info except parts list for '95
