Has Anyone Got A Pic Of How The Dics And Pads Set Up Looks Like Withou
John G
exactly as title, i need a comparison, as i took my wheels off the other day and i can wiggle my discs and there looks to be 2 screws missin on both sides
If you look at the pads and disc tutorial in my signature you should see some pics (GS and IS setup is the same on the front). There are no screws to hold the discs to the hubs, the wheel clamps them up tight.
cheers mate seens such a wierd set up, bein able to wiggly the discs just doesnt seem right even if the wheels do clamp them, madness
Hi as mattc says this is not an issue most modern cars do not use countersunk screws to retain the discs anymore; The 2 holes you have are so you can screw in bolts to 'jack ' the disc off should they not be as free as yours are
