Caliper Retraction Tool
Iceman2010
Hey guys, i know this probly is a bit off on the lexus forum but i need to change some rear pads on my dads avensis and i need a tool to retract the caliper (turn & Push) can anyone point me in the right direction for a cheapish one????
I'm sure I got mine from Halfrauds. Although a g-clamp should work also unless it needs to screw in the piston. In which case, normally a large screw driver from the side can screw it in.
Hi Halfords sell a 'Laser' make tool for just under £20 I have one and it works well ;the only thing is you only get 1 adaptor ,some cars have a slot and some have 2 holes for a spigot to fit into. check the one you want ,you can always ring Laser direct and they will give you a part number for the correct one ;I had to buy an extra one for Volvo Hope this helps
Dave
