Is200 Door Card Removal
remove screw (door opening handle cover(behind small flap)
remove screw bottom of door closing handle
remove tweeter speaker grill (just pulls off)
grab doorcard from the bottom, and pull towards you
disconnect speaker wire
disconnect window switch wires, and mirror switch wires
disconnect courtesy light wire
lift rear of door card out of window channel
remove door card
