Is200 Newbie Help
Indy
Hi guys I'm new here and on the look out for an Is200,
just a few questions,what are they like on fuel
is there anything I should look out for when Buying one any mechanical
problems
is there a big difference with auto and manual fuel wise
thanks Indy
Not too good on feul, av 25-30, everybodys different, but generally in this area
problems
No mechanical probs really, you may find a slight judder with clutch 1st gear when pulling off, sounds bad, but is not at all, just a common characteristic.
Take a couple of old cd's with you try out the stereo.
Check that there is a 3 button key (this is usually the master, will need this if copies are required)
thanks Indy
No, not more than a couple of mpg, so i'm LED to beleive.
Anyway, welcome to the club, happy hunting,
may would be a good idea to post in the wanted section, specifying age, milage, spec, colour as best you can
Deckie.
Yep ECU & Stuff, I was quoted £2K for new ecu, ftiing & 3 new keys cut from lexus Aberdeen, i got hold of a guy down south (via this forum) to flash my ecu & cut new keys for £500,
Look up
peace of mind security
Hull
Gary did the work for me. that was more than 2 years ago mind.
