v6 is200?
superchargedIS200:
where did u get all the modifications from? i looked at a few shops and everything from japan is ridiculously expensive. even a trd grill cost more than 200 here ~~~i bought one from hong kong, where i came from, it only cost me 100quid....
the grill,and body kit came with the car.
the rear spoiler i ordered from Toyota japan
supercharger from TTE in Germany,the sway bars from Takakaira in japan,and the other bits and bobs from other liuttle dealers around the world
check your U2U
Mat
V engine's tend to be a little torquier for some reason I'm not clever enough to understand (I think it's cylinder head design). The different firing order also makes the motor perform differently.
If it's going to be an all new V6 then it's bound to be a huge leap forward over the current and ancient I-6 :wow:
Most probably we get the camry engine or ???
i tot Camry uses 4 cycl engine ?
anyway, which provides a smoother performance - V6 or straight 6 ?
Nissan's new Skyline saloon (4 dr) has very powerful engine (better than Toyota's new D4 rngine) with good fuel consumption too - http://www.nissan.co.jp/SKYLINE/V35/0201/D...NEUP/index.html" target="_blank"> http://www.nissan.co.jp/SKYLINE/V35/0201/D...NEUP/index.html
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
