Projector Or Reflector?
Are you buying from HIDs4U? If so I have the anti-glare bulbs on my car (the reflector ones) and they do work better at reducing glare. HIDs work better with projectors as that gives them a clean cut-off, reflectors are not accurate enough for the additional light that HID bulbs put out. Therefore the anti glare have a bottom portion of the bulb obscured which prevents too much light firing upwards and in so doing reduces glare. The only problem with the IS200 is that the bulbs doesn't sit perfectly straight, so isn't as effective as it could be but it is much improved. Here's mine with the anti-glare bulbs, and you'll see the "cut-off" is much cleaner than it normally would be if you fit HID bulbs in a reflector housing. The angle you can see to the top of the beam is because the bulbs aren't straight.
