Gs300
tallyho
hi to you all going to buy lexus gs300 y reg with 161,000 with history is there any thing ishould look out for? what sort of milage are these cars good for its an auto with a paddle stick gear chage on steering wheel also would like your comments thanks
Suspension issues can be costly, so get balljoints and bushes checked out. Any vibration on braking through the steering can also indicate suspension issues and/or sticking brake parts.
Brake Servo is a common problem and very expensive to fix if it hasn't already been replaced with the improved item (couple of thousand for the part from Lexus, rare as hens teeth from breakers).
Not a mk2 owner myself so can't help beyond that.
