Remote Key Fob Needed.. Where To Get One?
I need a spare remote key fob programmed to work with my 05 Rx400h. Any ideas where I can get a good cheap one with programming instructions without going to Lexus directly?
I have a fob that you can have for £10 posted, I assume your RX has power rear door? you can get a key blank from eBay or local locksmith and have it cut.
Cant help with programming though.
Andy
Andy
Thanks for your reply. Is is a 3 button one with a transponder?
Andy
Yes it is a 3 button remote. You will need to source a blank key and have it cut then you can fit the remote and have it programmed.
Andy
Andy
Andy
Ok, I will take 2 please. Could you recommend the key fob with the blade on eBay? I want to get the best possible quality so looking for advice. Will try to programme it myself
  • 6 months later...
