Clock Illumination Question?
spurty
Got a 2000 IS200, having a Battery drain problem. :tsktsk: :tsktsk:
If i leave it standing the Battery goes as flat as a pancake over a couple of days
Trying to find out where the drain is from (have established its not the audio)
Noticed the other night that the clock light is constantly on, even when i turn the ignition off, is this right?? i would of thought it would be on a switchable live???
Got a 2000 IS200, having a battery drain problem. :tsktsk: :tsktsk:
If i leave it standing the battery goes as flat as a pancake over a couple of days
Look on http://www.bahamutcars.com for the circuit diagram in the Workshop Manuals section - that might help you.
The clock should go out when ignition is off
Thanks, thought as much.
Traced it..... poxy amp by-pass wiring loom that i bought off eBay, was causing the drain.(so it was the audio ggrrr) Either its faulty or wrong? i thought there were only 2?! hey ho i will buy another and try that!
I got my autoleads telemute lead from www.nexxia.co.uk (I think), pretty sure they do all the cables. They're reasonably priced and were happy to give me quite a lot of support over the phone so highly recommended.
  • 6 months later...
  • 1 month later...
  • 1 year later...
