Sat Nav Update Problem
Hi all after some quick help, i bought a 2006-2007 version 1 disc from ebay put it in and its saying to insert right DVD.
I have an IS300 which is a version 1 any ideas please ?
hi,you have probably bought the wrong disc off eBay,take out your old disc(assuming you have one)and write down the numbers,then go to the lexus map updates web site and put these numbers in,it should give you the latest disc update along with a part number.You could also phone up lexus and see if they would provide you with the disc number.I also made the mistake of buying the wrong discs off eBay,before opting for the latest updates.Hope this helps
