Altezza Diff Is 200 Diff
m_0_m_0
hi people,
unfortunate news, spun off in black ice and writ off my tezza, question is that i have rear suspect suspension damage dnt look major but on the extreme side wanted to know if the tezza diff is any different to the is 200 diff just in case it needs replacing
many thanks
only the autos had a different ratio, if you let me know whats damaged on your diff i will be able to help, but, the altezza and is200 diffs are interchangable, the internals are interchangable and the half shafts are interchangable
kool, well i dunno if i have damaged it at all, from what i saw the drivers side rear wheel looks like its got heaps of camber and toe in butttt this is probably due to hittin this tree stump first, from initial looks it maybe just be the hub and suspension arms. only just got the car back but waiting on payment. will need to get in on a ramp n check what the damage is underneath hopefully not too much. but i will keep you posted bud and many thanks for the offer of help as i may take you up on that if its worse then it looks as i wanna try save money in gettin it repaired so anything i can do i will.
fingers crossed
cheers mate appreciate it.
