I have a 2007 IS250 SE-L and have recently noticed that the steering has become very light and sensative.If travelling on a straight section of road the car goes over a slight dip/depression the car veers of to left/right.The steering has always been very positive but I have had problem with starting from cold and doing a hard right turn,I occasionally get loud knocking from front suspension.Anything similar or any ideas?
Perhaps a a tyre pressure check is required given the cold temperatures for your light steering. Also 17" tyres may be prone to tramlining.
The "loud knocking" has been covered on a number of posts so search around for wheel stepping out or knocking and you will read it appears to be normal behaviour, especially with cold tyres.
Hope that helps.
Hope that helps.
Thank you -will check tyre pressure(once snow clears!)also will check other posts regarding knocking-thanks again for advice
