Help Help Help
lex 85
i was driving home last night and my car started to have a judder/wobble from n/s/r doing about 40mph, i pulled over thinking its a flat tyre but tyre was fine, it also seemed to judder on tickover being stationary! can any1 please help thanks luke
hi when stood still it was like a slight misfire sort of wobble if that makes sense, i drove to work this morning only a ten min drive i didnt really go much over 30 and didnt feel it that much, it does it when going 40/50mph but last night it was quite bad it was like the n/s/r was wobbling its the 1st time its done it
You may have a plug down or damp on the electrics somewhere, the snow is thawing out now I take it you had antifreeze in? cant see it being anything to do with wheels or brakes as you you have in on tickover so it as to do with electrics or compression, how far had you driven before it had started to jodder ? if you didnt have it on tickover i would have said check to see if you had a seized caliper
you never said anything about back end wobbling? which could be a rear seized caliper are you sure it judders on tickover, dos it get worse the longer you drive say over 3miles
just had same thing. turned out to be a seized front caliper.
Thats why i asked about wobble on tickover? mine was a front seized caliper it drove perfect for the first couple of miles then i got the vibration bad
A bit of a shot in the dark, but it is worth checking the engine mounts if it also is a bit shuddery at tickover - loose/perished engine mounts can cause some strange effects when driving.
