Brake Light Fuse Suddenly Blows
It sems as though I have suddenly developed a short circuit. For no apparent reason, my brake ligh fuse blew and I have replace it twice and the replacements immediately blow as well. There has been no damage of any sort and there have been no modifications whatsoever.
Any ideas?
1992 Lexus LS400, 192,000 wonderful quad-cam miles, Phoenix, Arizona.
Email me
Any ideas?
Email me
You obviously have a short of some sort. I would start by checking the wiring and the bulb holders to see if there is any damage/corrosion and inspect each bulb. Assumming that nothing is obvious, and with all the brake lights disconnected, try each one. This will either find the faulty unit or enable you to discount the lights/bulbs themselves. If that is the case then it is likely to be a fault with the brake pedal switch.
The following 2 tutorials may prove helpful. The first relates to accessing the high level brake light http://www.lexls.com/tutorials/lighting/upperstoplight.html and the second relates to wiring issues in the boot (trunk to you) http://www.lexls.com/tutorials/lighting/bulbout.html
Please let us know how you get on.
