Gas Conversion
why not, I can't see the reason.
don't try to find a cheap place to do that is the advice. 1600 - 1800 would be reasonable.
Good luck.
Felix
P.S. Make sure you find someone has done a few of these and insists a flash lube kit is needed.
O sharp tank is waste of time, get a big one behind the seats.
Hi have a look on this forum and see how many have a gas conversion and alot have had problems with engine misfire it seems a hit and miss affair if you get a good conversion or not but at the end of the day its your choice just make sure you research your installer good luck
Im running on petrol at the moment and im planning to get a gas conversion any advice or tips??
Lexus is200 auto
Basically don't. You need to be very sure that you will recoup the costs of doing it, plus performance WILL suffer - this is unavoidable but may not be significant. Personally I do not know of anybody who has not had problems with conversions or sourcing the fuel - some with real horror-stories - although I am sure there must be those who are completely satisfied. LPG conversions have been about for over 25 years, and you have to wonder why they haven't really caught on.
