Is220D Display On And Car Will Not Lock
Help,
Can anyone give me some advice as to what the problem is here?
The display including warning lights for seatbelt, engine, brake and Battery will not switch off.
The doors will not lock
The car will not start.
I have tried to use a booster to start the car but to no avail.
Any suggestions as to wha may be the problem.
had the same problem on a previous car ,i removed the negative Battery terminal and reconnected it ,this solved the fault,A word of caution though, disconnecting the Battery will clear any fault codes ,they might prove useful should it not work,, best regards a114n
