New Lexus Ls400
SGTFUZZ
NEW LEXUS LS400 but it my first lexus
well my name carl im from northampton and i have drove a mercedes 190e
Now i have just got myself a 1991 ls400 1 small problem gearbox has gone so in need of a gearbox plz
CAN SUMONE HELP
JUST SUM SPECS
WELDED DIFF
LOWERED
CARBON WRAPPED BONNET AND BOOT
EXHAUST SYSTEM
INDUCTION KIT
Hi and welcome to the LOC.
I saw this one on eBay, as Malc says Maurice usually has some transmissions for sale,good prices too!
If you're planning on using it on the road I would also replace the welded up differential,they are OK for drifting but will wear your tyres out quickly on the road and this may have contributed to the transmission failure.
Some good resource sites are www.lexls.com and www.lextreme.com not forgetting this forum of course!
Keep us updated on the project.
It should fit as it will be the 3 speed with overdrive transmission on these models.
The part numbers are different
35000-50013 for the 07/90 to 07/92
35000-50070 for the 08/92 to 09/94
Lexus often change part numbers on a year change but they are the same thing,when I ordered my lower ball joints the part number had been changed 3 times but it was the same part.
There may have been slight differences perhaps with the gear ratios but physically it should be a straight fit.
If you can also get the matched torque convertor and the transmission ECU with the donor transmission that would help.
I noticed there is a differential on Fleabay too if you are replacing that as well.
