i only have one key for the lex so i'm looking into getting another cut and programmed. ideally i could do with another fob aswell. so can i get a key with the buttons on it from lexus or will i have to get a key and fob seperately???
also, does anyone have the part no. for the key and fob that i need???
the car is a mk1 1996 model.
thanks
key and fob it is then. i too hope it's the master key. i do have a code in the paperwork for the key so hopefully lexus will make use of that and sort one out.
Be careful until you know if it's Master key. Check whether it locks/unlocks the glovebox. Under dash/steering wheel side is a lock barrel. If you press it accidentally the boot will only unlock with a Master key.
checked the key in the glovebox and the little barrel under the steering wheel and it works ok. definetley the master key.
Thats good news. :)
