Red Warning Light
martin dlc
hi can anyone help my is 200se has this problem the brake failure light is permantly on ((o)) looks like this,
thanks.
Brake pad limit indicator? Check your pads.
Nope the IS doesnt have pad limit indicators
Have you fitted LED bulbs? if so that will cause it
If its the handbrake light you have a brake light out, check the high level one
