Is200 Windscreen Washer Bottle Hard To Change?
Ok so...ive got an IS200 54 reg. Did a weekly check on the car and put water in the windscreen washer filler. Two days later the missus says there is no water coming out of the jets. Checked the bottle and all the water is gone. Filled the bottle up again and checked underneath the car and it was leaking from the left hand front side of the bumper. I can only presume its cracked the bottle with the cold weather? Dont think the pipe has come off because when i fill the washer up and try cleaning the windows, water does come out of the jets.
Can anyone give any suggestions as to how hard it will be to change the bottle?
Thanks alot dan
