Is200 Failed Mot Today
shagx
My is200 failed its MOT today due to play on the offside rear wheel (slight movement on the wheel when jacked up left to right and up/down) the guy advised this may be a rear wheel bearing. Is this easy to change and is any special tools required?
might not be the bearing it could be the lower hub bush it has the same symptoms as a wheel bearing.
Are you talking about the transversal or the diagonal arm?
the bush in the rear hub.....
  • 4 weeks later...
