Hi folks.
While swapping out the rack boot I noticed a bad leak from the near side rack. Explains why the boot was shot.
I see that it's not uncommon but I can't find any repair kits available for it.
There's a crowd on ebay selling refurb'd units for c. 300.
Any recommendations?
Thanks,
EDIT: found the part number on toyodiy for the gasket kit. Is this a straightforward job?
Hello,
I've never rebuilt a steering rack and I think there are certain proceedures to preload the rack which are not DIY friendly.
Do you have a local steering specialist that could do the rebuild for you?
It may be worth contacting Smithie at the Soarer Sanctuary to see if he can either supply a recon or rebuild yours.
Thanks mate.
I've sourced a used one so the pressure is off so to speak.
I might have a crack at rebuilding it over time and if it goes belly up I can always cut my losses. I'd have to give it a good ragging around a SC carpark afterwards before I'd be happy taking it out on busy roads.
Hello,
I had a root-around and couldn't find anyone else with this issue, maybe time is taking its toll? Is it possible bits where out on these cars?
I think my exhaust gaskets are going,noticed the other day I can hear the V8 roar under accelaration,does this mean I can actually use that impact gun I bought from Aldi 3 years ago! :whistling:
I've read a few comments on American sites referring to a common 'leaking rack' problem. But, it certainly doesn't seem to be too common over here.
I unhooked the faulty rack this evening - no problems, however I can't get the steering column off of it.
I've soakted it with a healthy squirt of penetration oil - just wondering whether anyone has come across this problem and how they surpassed it?
Oh, btw, the old fluid stinks ! Looking forward to getting some new fluids in there. Any other preventative measures recommended while I'm working on the steering?
Thanks all....
