Power Window Failure
Dear all,
As title suggests, the rear passenger-side power window won't work and the window is stuck in the closed position. Vehicle is an X-reg IS200 Sport.
When I pull/push the power window switch, I can hear faint clicking noises coming from the door, but the window won't slide up/down.
Any suggestion? Thank for your time! :)
Dear all,
Hi,silly question have you tried both switches?that is the master and the rear passenger side switch?if both dont work,it could be the motor.
