P1346 Engine Code
andywright07
Hi am new to this forum but ive read alot of posts relaiting to my topic but cant find the answers , basically ive got an is200 ive just done the head gasket , when i first drove it after the work was done i had a misfire which was down to a coil pack , then 30 miles after that engine light come up with p1346 , i know alot of you say its down to timing , but once the error was erased it come back with in few miles but since after a oil flush and change of oil and clean out of the vvc valve i have done 250 miles and the light just come back on could this be timing or a dodgy vvc valve ?? has anyone experianced the same problems ??? cheers Andy
Your timing is out (probably by 1 tooth). Get the garage to pop off the timing belt, re-align the timing then put the belt back on.
