IACV
I'm trying to find the cause of the low idle I have occasionally, which disappears when the AC compressor is turned on. I've cleaned the throttle body already, which has resulted in a slight improvement, but I'd like to check if the engine has an idle air control valve I can check. Can anyone advise?
