Headlight Abs Question?
RSJ
Hi all, I've got a bit of a problem. with my is200
My headlights don't work. However if I flash my headlights/high beem from the switch the headlights stay on, untill I either unplug the headlight relay or unplug the wash headlight switch.
What I've found is the abs modual smells burnt.
Does the headlights run through this?
Would anyone have a wireing diagram for the headlights?
also, If it is the abs modual (abs works by the way) as mines a auto Are the manual ones diffrent?
I've read loads on this site already, but mines diffrent..
It's got my head done in abit :crybaby: , so all help is more than welcome
I think it's usually a headlight relay problem when this happens - has the windscreen been replaced? This is a common problem if it isn't sealed properly, water gets in under it into the fusebox and stuff.
Hi, It isn't the relay though this time
problem is, is that the relay doesn't have a feed from the switch (even though the switch is working)
although if you flash the main beem, the relay gets a feed and keeps the headlights on.
I'm almost sure it's this abs box, but i just wanted someone to confirm it before i splashed out :lookaround:
