Leak Under Car
Noticed what seemed to b a pool of oil under my car after footy before so got it home and inspected it. Just need to no if my assumption is right. When I looked under the bonnet it seems to be coming from a metal block attached to the side of the engine (left side when looking from the front of the car) which in turn has a tube going to the power steering fluid well. Would I be right in thinking the power steering pump is leaking?
What colour was the fluid? If it red then it could be coolant, so if then check the radiator, pipework and also the waterpump as well for signs of leaks.
