Reversing Lights / Power Steering Fluid
Hello folks,
I still have my 2002 IS200 SE Auto and would be grateful for following info that I can't find in handbook.
What type are the reversing light bulbs and what sort of LED ones should I use to replace the existing "normal" ones?
Also the power steering fluid level is at minimum so I presume it needs topping up. What sort should I use for this please?
As always advice will be gratefully received.
