Dvd Player
ruifm
pretty standard, loads of info on the web, all you need to do is disconnect the speed pulse wire from back of unit (Pink) so the system thinks you are not moving, best put switch in this one as the nav is a bit lumpy without it and then you need to ground the red handbrake sense wire.
don't watch dvd's whilst driving as its dangerous + you will get nicked, i have only done it so the sat nav buttons work as i thing its less dangerous than having to stop on a motorway to change something, at least your passenger can do it for you!
Ben
