Headlights Not Turning Off
deano77
Hi all only just got my lexus is200 sport and I've already encounted a few problems when I turn on my headlights I can't turn them off from inside the car,but instead I'm having to pop the bonnet and pull out the fuse/relay for the headlights.can anyone help solve this problem is it the sensor on the dash or something with the fuse box itself.
I live in west Yorkshire so if anyone knows of anyone who can help or a recommended garage that would be great.don't wanna use lexus main dealers has ££££££ so can anyone shed any light on this.thanks all
This has happened to a lot of people on here who have had windscreens replaced - it's caused by them not being sealed 100% properly and water getting in to one of the fuseboxes. There are 4 on the IS, check them all for any water ingress to rule that out first... Think it's the one in the driver or passenger footwell that usually causes this but I can't quite remember...
If you get down beside an open door and look in you'll see the panels in the footwell trim where the fuse boxes are - you may have to undo a screw to get into them though, you're looking for a small square "door"...
As to drying them out... erm with a hairdryer? dunno tbh, but I know this has been covered on the forum in a few cases. Chuck "lights won't go off" into the search function and see what turns up :)
