Help Please
lex 85
Hi I've noticed a rattle/clanking noise coming from rear passenger side, sounds like it's coming from wheel area, it does it mostly when going over speed bumps, it sounds like something maybe loose??? It's driving me mad as i can't find where it's coming from!! I took the wheel off and found the brake dust panel was loose I sorted it out but the noise is still there!! Please can any1 help
this may be the clip retainers on the rear that hold the pads tight in place, these may be missing, put your finger in on top of caliper until you can feel the top two hooks of the brake pads, if you locate the pads and they feel loose (rattling about), you will then need to get these clips which you can get from lexus / toyota or a scrap yard if your lucky
hope this helps
And also just checked again the pads also have play in them! It's been doing my head in for ages thanks again
if the retainer is still there then try taking wheel off, remove pin and take out retainer, now all you need to to is bend the retainer back into its original position so that when put back in it holds the pads tight, hope you get sorted, that very same noise ****** me off for a week or so til i figured out the problem lol
