Couple Of Problems...
Hi all,
First up, my new Sony stereo isn't working any more, I suspect a fuse. Can anyone tell me where the fuse for the stereo is in the car so I can replace it? Also - are there any other systems linked to this fuse that will also now not work so I can be sure it is that that is the problem?
Second up - when the car is left to sit for a day, when I start it I get the smallest little puff of grey smoke after the car turns over for a second or two. It's defo not blue, so is this just a little unburnt fuel just burning off as it takes a couple of cranks before the engine fires?
Thanks in advance all!
There's a 20A fuse called "Radio1" in the fuse box in the engine bay just in front of the Battery.
A fuse called "Radio2" in the drivers kick well fuse box.
The electrical wiring diagram workshop manual is among the ones found here - manuals
From that it looks as though the following are some items associated in some way with the Radio2 fuse :-
Satnav, clock, wireless door locks, windows, interior light, mirrors, shift lock, a/c control, body ecu. :wacko:
Seems quite a lot but that's just from looking at the car wiring diagrams and probably not taking all their power from there.
Hope that's of some help :shifty:
TG
There's a 20A fuse called "Radio1" in the fuse box in the engine bay just in front of the battery.
TG
Thanks for this - it actually helps a lot!
Cheers :)
Also bear in mind most radio/cd players have an inbuilt fuse in the unit normally where the multiplug fits in at the rear.you normally prise out the fuse holder with a small screwdriver to expose the fuse.
They also normally have 2 supplies 1 constant and one switched via the ignition (normally red and yellow wires) make sure you have supplies to both with the ignition in acc position.
