I am trying to check engine oil level on my is 250 with the dipstick. When i initially pull out the dipstick, the oil is very high up above the max line, but then when I wipe it with a tissue and re-insert it and check the line I get a more accurate reading, but there is also thin layer of oil marks going above the max line even though i wiped this down. Can any one tell me why this is? I dont know which oil mark to actually use to determine oil level. I'm assuming that i use the line that has a thick layer of oil and that ends in a straighline and covers the dipstick 360 degrees.
