Compatible Wheel Sizes
Hi, I am looking to get some new wheels and Ive seen some on offer, this is the size details 18×8 (5×112 ET35)
Just wondering if they would fit the IS200?
the size and the et are just ok(if you are low you will need to run 215/40/18 tyres(thats the same spec of wheel as me)
but the pdc is all wrong..sorry mate
Ahh thanks for that, its ok will have to carry on looking, im quite fussy about wheels, theyre like expensive shoes.
wobble bolts?
I had my pcd altered by TT tools in Chelmsford,no need for wobble nuts,proffesional set up and it only cost £50.00 for four wheels,it took about 45 mins to get them all sorted. www.tttoolsltd.co.uk.....you'll need spigot rings and as Ormi said you'll need to use 215/40/18 tyres..Offset (ET) of wheels, Increased or reduced
The Wheel offset is taken from the wheels centre line and measured to the mounting face of the alloy wheel.
There are two main offsets Positive and negative, We can create both, either Increasing or reducing the offset using our CNC Machines.
Using our CNC machines we can Skim 5mm off most pre-drilled wheels, (ie. ET35 to ET40)
Blank wheels can be machined to almost any offset.
