Taillights From Usa
They will be legal
Are you sure?
If they're from the USA then chances are they'll have red turn signals integral to the brake light.
Nope they wont, they will be legal
the wiring is the same as the IS200 for the rear lights def
You just need to make sure they have a reflector section in them. If not, you would have to put some separate ones on the car to remain legal.
They will be legal
Are you sure?
I am positive
Hi,as far as i know,they are legal,just bear in mind only the brakes/parking lights are l.e.d.s,you will have to use normals bulbs for the signals and reverse.
If those are the ones I'm thinking of I think the circle in the middle of the brake light is a reflector.
