Left Hand Is300 Bits
Would IS300 accelerator brake, footrest and accelerator pedal of a left hand drive IS300 (US Version) fit on a UK IS200 model?
Regards,
Nik
Hi mate I fitted Left Hand Drive IS300 brake and accelerator pedals in my is200. Brake pedal was straight fit, accelerator pedal had to be removed from the actual arm as they were different. It's held on with a metal pin so needs hammering out with a pin punch tool. I assumed the footrest would be different so managed to find one at a breakers yard, which also turned out to be different but made it fit.
http://www.lexusownersclub.co.uk/forum/index.php?showtopic=72414
I fitted a LHD set to mine as well and exactly as above, brake pedal cover simply comes off so just swap those over, accelerator pedal need to knock the pins out and swap pedal. Footrest is the one that needed quite a bit of modification to make it fit.
