220D Problem At High Revs
hello, i have a problem with my is220d
year 2006, is220d se
i;ve done a search and cant find an answer.
The problem started happening a while back on and off, when i put car in first gear and put foot to the floor the car jerks around 3-4000 revs wont go higher without jerking badly
This happens in second gear aswell. I think it might happen in all gears but its just noticable in first and second because it revs up high easier.
The problem now happens all the time, when i put the foot down the car jerks and wont rev higher, have to change gear.
I did a search there and seen a problem about carbon building up on the cat etc,
Just wondering has anyone else experienced this problem or know a solution.
Hi we bought an 08 lexus is220d only a few weeks ago had it for a couple of days and noticed the same problem you've mentioned it has since spent the last 10 days back at the garage having a new engine block due to potential exhaust gas egr valve block due to carbon build up. Excuses given "supermarket fuel" replacement of block due to caution as lexus recognise a fault but they're not sure what it is. Apparently lexus have extended the warranty to 7 years or 118000 miles but have not made this official!!!
