Timing Belt Dimensions
funkey
Folks, I've checked my timing belt and found the width to be 26mm while the pully is approx 32mm
No point in checking if I can't tell if there's been any wear!! after a 10min search, I've been unable to find any mention of what the original width should be.
Cheers,
Simon
Cheers Igino! Looks like this starts the count down until I replace it. I'll be checking every 500 miles from now on since it only takes 10th minutes
