Any Cooling System Specialists Here?
Ruud
Here goes...
I (also) have a 2000 Range Rover 4.0 V8 (I know, I know :) )
The problem is that the thermostat won't open for some reason. The t-stat is brand new and checked.
The t-stat is located at the bottom of the rad so not in the usual top engine area.
Here's a pic of the system and flow
The engine will overheat when driving, but not on tickover - no matter how long I let it idle.
As said: t-stat replaced and checked, expansion cap replaced, system is 'burped'
Radiator flushed - all fine. heater matrix flushed - all fine.
I'm taking off the water pump tomorrow to see if the impeller is sheared of...... other than that, I'm pretty much out of ideas.
Anyone?
Hi Ruud,
I know this is a long shot but have you checked that the rad is clean on the outside?
I do a bit of off-roading and I get similar symptoms to what you have described when the rad fins get full of mud. It's fine on tickover and driving at 20 MPH all day but overheats within a few miles of normal driving.
Maybe you have something blocking the air flow through the rad.
I hope this helps.
Steve.
