I've burned mp3 files on a DVD disc, but the DVD player in my IS 220D cannot play the files. Ordinary music CDs work fine. What could be the problems ?
I found the same with my RX as like you I assumed it would handle DVDs but it doesn't. You can get some software which will burn a dvd with music and a menu but not as mp3s, just normal dvd audio so it won't fit as much on. Also you won't be able to see the menu screen while driving. I just gave up and used cdrs. I get about 60 albums across the six disks at least.
You can use a program called "Audio DVD Creator" to create DVDs that will store 700/800 mp3s. You will need to have the Sat Nav hack enabled to view menus and select songs. You can read more about it here:
http://www.lexusownersclub.co.uk/forum/index.php?showtopic=63307
